72blazerguy
3/4 ton status
What a day. Finally got time to assemble the 203/205 doubler. Was mating the 205 to the 203 and figured out that the shift rails had been installed with the longer rail on the wrong side. F*ck me, the doubler plate can't seat properly since the shift rail interferes. So much for not messing with the 205
So anyway, I researched some and it looks like the shift rails can come out if I punch the case plugs into the case and remove the roll pins. I have a few questions....is this the only way? what do I replace the plugs with? can I retrieve the plugs, how do i keep the shift fork in the proper position? are the roll pins re-usable?
Any input??
Any input??
