205 shifter wave washer
dyeager535
1 ton status
Solutions
1
Roy, Washington
Anyone got a source for this? The rattling while driving, without it, is annoying. Local place doesn't sell one large enough, and the GM part number appears to be no good anymore.
Anyone know if one can be purchased "off the shelf" from a large nut/bolt supplier? If I'm not mistaken, these are pretty thin washers comparatively, so a "thick" one may not work. I know I've got one around here somewhere, like I'll ever find it. Well, I will, as soon as I replace it.
i know the autovalue here has them. they keep them in the mystery cases that nobody knows of but the good counter guys. its not going to be in any book.
its going to be for a whole box, i'll look tomorrow.
what size is the bolt where that shoulder is that the wave washer rides on?
Tacoma Screw probably would have something that works, if you're ever down here.
mcmaster "disc springs"
nice link
Part Number 9714K58 1-9 Pack $9.49 per Pack of 25
10 or more $7.88 per Pack of 25
Type
Wave Disc Springs
Material
Grade 1074 High-Carbon Steel
System of Measurement
Inch
Minimum Inside Diameter
.719"
Maximum Outside Diameter
.925"
Thickness
.0100"
Overall Height
.066"
Deflection at Load
.033"
Load
6.00 lbs.
Part Number 9715K92 1-9 Pack $10.63 per Pack of 10
10 or more $9.30 per Pack of 10
Type
Curved Disc Springs
Material
Inch
Fits Hole Size
1-1/8"
Fits Rod Size
3/4"
.800"
1.103"
Thickness
.0210"
Overall Height
.138"
Deflection at Load
.069"
Load
12.00 lbs.
oddly enough gm doesn't stock this washer....even odder..the last time i bought a new 73 up 205 shift lever they redesigned the lever to have a large rubber bushing like that of a leaf spring....and it doesn't rattle.
DW
Dorman only makes them in metric and only up to 16mm in size. /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
