205 speedo plug
kgblazerfive
keymaster
Hooper, Utah 84315
I need a Ford 205 speedo plug thingy that the speedometer screws into that is in the T-case. Not sure if chevies are the same
I have the rear output housing of a Ford 205 and the speedo cable goes directly into the rear housing and then there is a small bracket that must be part of the cable that bolts the cable down. The Chevy and Ford housings are different because of this. The Chevy housing uses a threaded in adapter.
