205 Sye
is this what i need to rid my np205 of the long aluminum tailshaft? if so, i am interested in 1 of them. i will be back home on monday 5/4/09 and give you my address and paypal you the money.
i have a 1980 205 with the slip yoke, will that work for mine..? and how much of a job it it to put in...?..........if so im real interested....
Yeah this will be what ya need.It's not that bad at all,ya just need to be sure and keep up with all the roller bearings.
im looking for a rear shaft also for a short bed so i can use that from you...? do you have one of those...?
ok give me a day or 2 to see and ill get back to you, thanks.....
sorry i didn't get in touch today, i just got home & its 2:30am and i'm beat, i think i have your paypal, do you need my address or can you just get all that from paypal when i send you the money? i thought you had mentioned they were $65 shipped...now its $85 is that w/a yoke w/this 1, think thats what i'm reading? i'm buying a 32 spline 1350 yoke,so don't need a yoke, but will buy it also, if you don't want to sale just the shaft & other parts to convert w/o the 1330(correct?)yoke..just curious why you went back up.
i think i ran across another thread where you had some other stuff for sale...namely a 32 spline front output, is that you, do you have another thread w/other stuff listed?
edit:my bad, its sweet k30 who has the 1350 yoke i'm trying to get for this shaft, who also has the 32 spline front outputs. and no, i don't have a pm from you w/ your paypal info, if you would pm me this info, i'll get the money to ya?
sorry-i had a little stay in the hospital-story in the lounge- i will send you the money in the morn, if you still have this. is the shaft & retainer everything i need to swap to the yoke? this is for a 205, correct? the gear on the end looks like a sprocket for a chain,-that meshes w/gear inside the case, correct. i'll
All you need that you wont have will be the shaft,yoke and retainer.This is out of a 205 and the end of the shaft goes into a hub that connects the input-to the ouput.
i thought i was buying the shaft & retainer from you. is that not what you are selling, a 32 spline shaft & retainer? and i'm gettin a 1350 32 spline yoke from another member. sorry if i'm wrong..i've never tore a t-case apart...wouldn't i remove my aluminum tailshaft casing and the shaft and put my bearings on the shaft i'm getting from you and put it in my t-case w/your retainer and a new seal & then bolt on the 1350 yoke? then i will need a d-shaft w/the slip joint in the middle. isn't that correct or is there another shaft i will need? either way i guess i will need this, so i'm sending you the $ via paypal right now!
i'm headed back out of town, will be back tommorow...if my last reply isn't correct, i'll be on here when i get back or you can call me 501-827-2526 if you have an at&t cell it won't cost either of us...if not we'll get together online at the same time eventually
