Fellas
I need to remove my 205 from the back of my TH350. Never done this before and a bit intimidating. Is there a basic write up on removal or can someone post a quick explanation on how to do it. I believe it's just a matter of drive shaft removal, speedo cable removal and I think 4 bolts mating it to the adapter or end of trans, right???? once everything is unbolted does the t-case just slide off, out and down?
My reason to take it out is it is popping out of 4-Lo when under load. Think I need to replace the springs and little ball on the detent of the shift rails. It doesn't pop out in 4-Hi. What can yo tell me? THanks.
