205 tcase parts avalible soon. see list inside.
sweetk30
Back to play nice .
in the back of your brain
i plan on parting out 2 divorced 205 tcases i have in stock . parted out all units
2 fixed yoke rear units no yokes included . 70 shipped to lower 48. 2 gone
2 32 spline front units. 90 shipped to lower 48. both units gone
2 32 spline inputs from divorced cases setup for yokes. 60 shipped to lower 48. 2 gone
2 divorced cases dodge/chevy/ih pass drop style. make offer + s&h .2 gone
2 crossmembers from dodge trucks 1 all there 1 ends cut off. make offer + s&h. 2 gone
also other internal parts you might want to make offer on. minus the shift rails. all gone
1 30 spline front shaft & flat flange for c/v head 90 shipped to lower 48.
i would like a 32 spline front shaft, i'm gettin the 1350 32 spline yoke from you...if i put a 32 spline front shaft in my case, i can use the same yoke f&r can't i? the front output shaft, is it just a simple swap in place of the 27 spline?
the 32 spline fronts i have are to replace a 10 spline or 30 spline. 27 would be a input size.
also its a fairly basic swap out for the front units.
and yes a 32 front will take the same yoke as the rear. i might have both 32 fronts gone i will know by tonight.
I'd take a rear output. Whats included? Just shaft and retainer? I could use the housing and speedo gear setup too.
i was wondering if you have another speedo gear setup,mainly the shaft that goes from the 205 to the little gear housing,that then goes to the speedo cable thanks justin
both have been stiped out / checked for all parts to swap and ready to ship so please let me know and i can ship asap.
yep still have the 2 units. no paid yet. i have 1 older steel gear speedo and 1 newer plastic speedo gear setup minus the plastic gear. it was shot.
both fresh pulls around 2 weeks ago and ready for ship ass pulled.
:doah:sorry i plain forgot. i will get them tonight and post up here in this thread.
this weekend was crazy with the buildup and assembly of my doubler kit and tcase.
you will have first dibs on the choice of the 2 i have to offer.
I think I'm actually going to go with a setup from northwest fab so Philip can have first dibs. I would however like one of those T-case to frame braces you have with poly bushings.
Mike
will make you a smoking deal on both if you want to deal as i need this stuff gone.
and it will fit in a flat rate box so ship time 3 days max.
