205 to 4l60?
Well the 4l60 is a bomb waiting to explode but if you really want to... I believe the 80e and 60e use the same output configuration and there is a factory adapter available that mated a 205 to the 4l80e. It was on the 91 crew cab long bed 1 tons.
The 4l60 is the same thing as a 700r4, you can a different output shaft from advanced adaptors and use a 205 from a th350.
