205 transfer help
beto101
Phoenix Arizona
I'm working on. A 80 blazer and need to know what's the interchange for the 205 transfer case. It has the th350. Can someone help me out?
What do you mean? Are you trying to figure out what other trannys it'll work with? It'll be easier to figure out if you'd post up was you want to do with the 205 from an 80 K5 with a th350. :wink1:
205 help
I need a replacement 205 transfer case. I need to know what years will fit on my th350 for my 80 k5.
205 help
I guess I need the whole transfer case. My adapter is broken where the shifter goes. the case itself is no good. I'm looking what other years and vehicles I can get another transfer case from
Any year will fit as long as the 205 was behind a th350. there are some shifter & linkage differences on the very early set ups (71~72 type) but even those would work.
Beware that there are different tailshaft set ups - bolt on yoke vs slip yoke. Your K5 is probably a slip yoke. If you find a case with the opposite tailshaft from yours, the parts can be swapped relatively easily.
Just so you know the fixed yoke tailshaft is prefered and isn't too bad to swap out if you have a little mechanical know how. The fixed yoke requires a different rear drive shaft though. I think I may have one if you need one PM me.
Got one in No. Cal if you strike out there, freight would sting!
