My speedo stopped working, I pulled the speedo cable at the t-case side, found that the speedo plastic gears teeth are all gone inside the t-case. How do you replace the speedo gear inside a 205 transfer case? Do I need special tools? I know for sure I need to remove the nut that is holding the yoke, plus the little housing etc.. Do I need to a bearing puller?
Can someone please enlighten me on how to replace the plastic speedo gear inside a 205.
Thanks in advance!
Tom
Thanks in advance!
Tom
