Hey guys i have a k5 w/ a 350/700r/208. My 208 wont stay in 4high. I adjusted the slider on the linkage so there is very lil play. Then brought it to a field and just romped on it in 4high, it still didnt hold, it falls out into 2wd. As well as i can watch my tranny shifter jump a bit up and down. Could my shifter arms inside the 208 be dead for 4high? it works in 4low just fine. Truck drives fine in 2wd as well i can slam on the gas and nothing pops or moves. The cross member is tight, the tranny mount bolts are tight. So maybe the tranny mount is dead? The truck also has a 6" suspension lift, 14bolt rear 4:56 and detriot.. D44 4:56 up front if that means anything. Thanks for any advice guys!
