Quick question that I used to know the answer to.
I'm changing from a np208 to np241,
I know in 95, the 241 changed to a different bearing thickness on the input shaft. If the case is complete with the shaft, is there any difference on the input/transmission part that would effect fitment? The only difference was internal to the 241 correct not where the transmission is concerned? Please help as I'm bout to pull the trigger on a case just need to make sure
Edit to change year.
