Obviously, I have a np208c in my 88k5. I'm going into a transmission rebuild. I've read that rebuilding a 208c would be better served by replacement with a 241c. If that is true, does everything bolt right up to a 700r4? Does the new XFR case change the driveshaft lengths? The 241c I found said it came off a 89 k2500 with manual transmission. If this is a better XFR case, then what would I have to do to make it work for my k5. I already fixed my driveshafts to work with the 208 to the 1 ton axles. Thank y'all for your help!
