you could go 203/241 no problems, dont most the 203/205 doublers want the 32 spline 6 round 205? you could just swap the 241 in its place, it (can be) 32 spline, and its 6 round. as for the 241/205 you would have to figure that one out, when you put a 205 behind this doubler, you have to clearance the clocking ring for the inside shift rail of the 205. you're on your own as far as the figure 8 thing though, the shaft that d&d supplies is not long enough to run a spacer to convert it to figure 8.
btw, the NW fab's black box is basically the same as a klune v, basically the same as a 231 doubler. its the same gear set, just a different package.
