241 adapter question
I can't see why they wouldn't be unless GM decided to make the bolt pattern different between the two just so you couldn't do a swap easily. Actually that is the only difference i could see there being and i doubt that GM would do such a stupid thing but then again i've been wrong before about that one. Maybe someone else with a little more knowledge about the driver drop will chime and and give you a definate answer.
