k5 krawler 50
I've decided to go a different route with my project and will no longer be needing this case and adapter. It is a drivers side drop 241 cut in half and bolted up to a D.D. Machine 241 doubler plate. the case is fully welded and ready to go, all you need is a second case. This kit is brand new, and never been ran, let alone finished. Also i have a th400 to 241 adapter that i'm also going to sell with the case. I'm looking to let this go for 625 dollars SHIPPED, o.b.o.(if you are out of the lower 48, i'm sure we can work out something that would be reasonable for both parties). some specs on the case:
241 drivers drop, cut down and welded up(professionally TIG welded)
32 spline input
the intermediate shaft is a 23 spline output(for dana 300 cases) but D.D. Machine does sell other shafts for other cases.
If there are any questions dont be affraid to ask.
A couple pics of the case:
before the cut and weld:
32 spline input
