241 Pump Retainer Housing Cracked
fwc
Northern Virginia
As a result of a u-joint/slip yoke failure my rear driveshaft smacked the back of the transfer pretty good. The "pump retainer housing" ended up with a crack around one of the bolt holes. Does anybody know where to get a replacment? Is it possible to weld the piece back on? Any suggestions? For what its worth, my Jimmy is essentially stock and is a daily driver. Thanks in advance /forums/images/graemlins/thumb.gif
