That’s what I hope. I went to a lot of different places only one place said they would do it for $350good tig welder can fix that if you dont find parts .
screw me that price . . .It's crazy what some people think is reasonable.That’s what I hope. I went to a lot of different places only one place said they would do it for $350
Yeah I thought I would ask around before getting it welded upIts too expensive to be an insured welder with any kind of professionalism like a shop to take it to or mobile tig. If it isnt 350 minimum, its not worth the effort for the time it takes.
Being that replacement part is more scarce than 350 bucks, it might be worth it to repair.
It’s already off but I didn’t post all the picturesMy local shop would probably fix that for less than $100 once you took it off of the case. Hell, they have fixed diesel tanks for me with $100 invoice.
@Babaganoosh do you have a spare housing?
Wow. How did that happen?It’s already off but I didn’t post all the pictures
I might, not sure of the condition anymore though.My local shop would probably fix that for less than $100 once you took it off of the case. Hell, they have fixed diesel tanks for me with $100 invoice.
I'm pretty sure I have a housing laying around. I'll take a look when I get home.@ashman maybe you could check with @the_blaze and see if he has parts?
Okay thanksI'm pretty sure I have a housing laying around. I'll take a look when I get home.
I’m pretty sure they dropped it went to a junkyard I haven’t been too they also had the whole truck on a frame but it was held up by the driveshaftsWow. How did that happen?
I have seen a crack or one ear broken.
This is baaad
I just checked. I have 3 241s here, but they are all speedo cable housings. Only VSS housing I have is on the blazer.I’m pretty sure they dropped it went to a junkyard I haven’t been too they also had the whole truck on a frame but it was held up by the driveshafts
Dang okay thanks for looking.I just checked. I have 3 241s here, but they are all speedo cable housings. Only VSS housing I have is on the blazer.![]()
any luck?I have mine 20 miles away from where I live.![]()
