255/85/16 KM2's
pseudomike
MA
Anyone running these on their dually? Thinking about picking up a set just curious if they clear on the factory wheels? Trying to avoid spacers. Going 19.5's if I have to.
pic of my test fit of cooper stt 255/85/16 static weight no loads or anything . c&c axle also.
if spacer then check and make sure it will center the outer rim. the drw rims center off the hubs not the lug nuts.
and if i was to do a drw i would go 19.5 my self.
Looks like enough clearance. How do you think it will do with weight in it? Dead set on not running spacers I have had issues in the past. I probably won't put more than a few thousand pounds in the rear but I do tow a 18k lb gooseneck with it occasionally. I have 19.5 wheels but they need attention. They are off a P30 bread van an stick out a little more past the fenders than I like but look cool. it is the full width dually with the D70HD.
cant tell ya on weight. never ran them. sent them back. didnt clear my srw flat bed. and had 3 other sets of tires that fit otherwise.
at work i have seen lots of should work and shouldnt be working. so its up to you.
