27 spline np205
85 Jimmy
Sheepdog
Gulfcoast
i've been looking for a np205 to put behind my 700r4 since i blew up my np208
I've got a clean one; complete with adapter and shifter, rear slip yoke model with 1350 yoke included; $300 plus the ride.
Jimbo
could you figure out shipping to 39531 or could you tell me how to?
is that the same slip yoke that's on a 208? is there any internal difference between the ones with the slip yoke and the ones without one?
could you send me pictures to [email protected]
I would imagine shipping to be around $150, but I'll check this week.
Yes, the same slipyoke from the 208 fits the 205.
The internal difference is the output shaft and bearing retainer/seal housing.
I can install a slip yoke eliminator on it for an additional $75.
Jimbo
edit: just re-read your post, you have a 700R4. This requires a spacer between the tranny and adapter. Do a search on here to be sure you want to go the 205 route. You might consider a 241 instead.
well i plan to do a doubler later, but i will search some more
i'd like a more solid case and from everything i've read the 205 is pretty much bullet proof. iirc the 241 still uses a chain
this should be all i need Switch Kit adapter (PN TP7Q-35A) from Auto Matic Kings plus some driveshafts. i might end up putting in 3/4 ton axles at the same time so i'll need new shafts anyway.
