PhredzK512
What is the advantage of 30 spline over 27 spline on the axle's? Is it interchangeability,strength,durability? I was reading the CK5 specs and on the '89's up GM went with 30 spline axle's and I'm trying to explain to my wife if there is an advantage to this. Even whether if swapping out the GM 10bff for a 14bff for beefier ring & pinion is all worth the consideration.
I have a '87 CK5 Custom Deluxe/5.0/SM465/NP208/31.10x15/10Bff
It ain't pretty but,...gets me where I need to go...
