I need to order more chips and think from reading the 2732 is what come in the 1227747 but the 2732a is a better chip that will work the same with a $42 mask in the 7747?
I've got a USB pocket programmer III already with UV eraser...I'm running one of Moates ZIF's...no soldering required.
If I got off my rear and tuned it I'd be able to ditch the ZIF so I could put the cover back on the PROM....but the trucks been in dusty environs multiple times and hasn't given me any problems as it is.
I think it's the "ostrich" that Southernspeed was running, and he had nothing but good things to say about it, and is probably the way to go if you don't have the EEPROM stuff yet.
Where the heck did you get a UV eraser? I figured those went the way of the dinosaurs. Not making fun, just folks were steering me away from UV when I first started contemplating tuning over 4 years ago.
Me to but they had one at
So it just hangs out the top of the ECM? Said something in there about doing it differant and it will be lower? What do you do to erase this new chip?http://www.moates.net/index.php?cPath=26 ZIFs and chips are here
http://www.moates.net/product_info.php?cPath=25_36&products_id=36
I prefer to use the adapter, I've not had much luck just using a ZIF in the stock socket. He has directions on how to do it on his site. Looks like your programmer will support 27sf512 chips.
Craig has about everything you need.
I also know though, that my burning will take various edits, and even things like fan speed, or crank time before fuel are fun to play with, just a little bit here and there. This makes it easier, even for us old schoolers with the PP2.
Dam that kind of answered my next question.Most of the bad 2732s I had had previously been burned at the wrong voltage so once they were erased they were done. Come to think of it all the bad ones were surplus that came from ???? but the good ones were take outs from other car computers. That may be the ticket just go down to the pick and pull and grab all the PROMs you can find and leave the mystery surplus chips in the garbage.
