79bonanza
I just mounted my BFG KO2 285/75/16 on my dually wheels. I put them on the truck with no lift and they fill the wheel wells good with no rubbing. The tires on the rear do need a spacer but a 2" spacer is more than adequate. The bulge of the tire is only maybe a 1/4 past the wheel mounting surface on the stock wheels, so figure you want atleast an inch between the two when mounted on the ground so a 1.5" would work but a 2" is good if you just want the peace of mind and a little wider stance.
Just a heads up for guys wanting some wider tires on there dually.
