I’ve been think’n and need some input from some fellow gear head brethren…
I’ve gathered several parts for a 292 engine and am wondering about the water pump to crank pulley ratios on certain applications.
Most have a overdriven ( smaller than the crank pulley ) pump pulley ratio but every application that I have ( four different K-30’s ) that have come from K-30’s with 4.56 gears and have a larger water pump pulleys that is equal to the crank pulley making it a 1:1 ratio ( both being 7-3/8” diameter ) resulting in a slightly slower coolant flow rate.
I am wondering if this is due to the motor being able to be rev’d fairly high at sustained highway speeds and maybe the coolant flow would benefit from a slower rate and less pressure at such engine speeds caused by the low gearing - any thoughts or wisdom y’all could share with a knuckle-dragger ?
This also led me to another thought - up until 1974 these truck only 292’s came with a very larger coolant bypass hose ( 1-3/4” v/s 5/8” ) off of the water pump ( see pics ) and all of these seem to come with a smaller diameter W/P pulley that causes a higher flow rate - but after ‘74 they came with a smaller bypass hose and some came with the larger W/P pulleys slowing down the coolant flow.
Also, the C40,50 & 60 series still came with the larger bypass hose diameter and larger 7-3/8” W/P pulley and I assume this aids better in cooling while an engine is being worked hard and rev’d high.
Is my think’n in the right ballpark about the correlation between the ratios pulleys and coolant flow rates and their effects on extra cooling ?
I’ve got both setups that I can use but I would like to confirm that one setup is better for certain applications before I commit to using them.
Thanks, Tom
Thanks, Tom
