wetoolowdingbangow
Ok guys ive made a wonderful discovery tonight. Upon bolting on the ruffstuff srw and putting my assembled hubs on I found a major clearance issue. theres no way the bracket will work with my hubs.
I was unaware that there was such a thing as a 2nd gen 14 bolt. It's got all the ribbing on the pumpkin and it was what appeared to be the slide off drums. Apparently I cant switch hubs due to the bearings being closer together.
So now that its sitting under my truck I need to roll with the punches. Although I have the bolt on disc brake adapters that have the bend for 1st gen srw im thinking I can make them work but would like some opinions.
Being that the adapters are the same diameter as the axle tube I could cut the adapters to fit the tube and weld them on. Not sure if thats ok being that they have the bend in them? maybe ill just order weld on ones from ruffstuff.
Next issue is that my bastard axle is 65.5 inches wms. Based off rough measurements I may run into trouble with inner fender rub. I guess I may need wheel spacers even though im not a fan of them. I have dually studs so I would have to cut them down to be below wheel spacers right?
