I bought an 2wd 84 crew cab body with minor surface rust, will be swapping out cabs sometime down the road. My 82 k30 has deep rust under the paint in the rockers and on the upper door jambs. It wasn't bad until my kids poked around with it and I just want a solid clean truck.
I want to take out the '84 "non-removable" 2wd tranny tunnel and bolt on my '82 "removable" 4wd tunnel.... but before I do this, can anyone tell me if the tunnels are the same size? I know the 4wd tunnel is a couple inches taller than the 2wd one. Not sure if it matters any, but I have the 454/th400/205 combo, I guess that's the standard driveline. I figure ask first before pulling up the carpet.
Taking out the non-removable tunnel is easy, drill out spot welds.
Also found out the 84 cab is a Camper Special, it's got the teepee emblems and the thicker lip in the rear glass rubber seal for the camper seal. Not sure if this is limited edition or what. I don't see any other differences other than the tranny tunnels.
EDIT: I think I type as funny as I talk, had a major brain fart... Changed "pan" to "tunnel". Thanks 4x4high...
