Peteasauras
Registered Member
Can I use a 2wd 700r4 to a 203/205? I think the only difference between the 2wd and 4wd 700r4 is the rear adaptor and the output shaft. I already have a TH350 to 203 adaptor and will need to changeout the 7004r rear shaft anyways. So is there any reason I can't use a 2wd trans? Any other potental problems?
Thanks.
Thanks.
