2WD Front End Rebuild
longbedder
3/4 ton status
Staff member
Moderator
Ridgecrest, CA
It's time for a front end rebuild on my 1994 C2500 Suburban - I want to cover the whole thing. I plan on poly to replace the rubber parts.
What parts am I going to need to do the job?
How many miles are on the beast? Per
Personally, I would only change what it needed. But, if you have to, upper and lower ball-joints and tie-rod ends.
You want Napa Premium parts (the ones w/the lifetime warranty) or Moog parts...nothing else. You definitely don't want Autozone crap...trust me
Also, you want rubber parts. They have more cushion and give a better ride and I think (not sure) that they last longer.
any time I have done a master swap on poly stuff I just buy the master kit from energy suspension .
and fyi on 2wd 88-98 stuff . if you need to do motor mounts do them with the coil springs out when the front end is apart. the mount bolts are up in the coil pocket.
