so i might want to make 1 of my 3500-hd trucks 4wd and the axle is ULTRA RARE to find and about useless to try and find .
so i have the idea of make my own axle for the front like guys have been doing on buggys and such now for years . i have a question tho .
does the king pin width need to match from 2wd I-beam to 4wd width wise ? or is the narrower width needed for the 4wd stuff ?
these 3500-HD trucks use a 33" width center pin to pin spacing and our old trucks are 31.5 and newer fords mid 80's are 36.5 but same wms to wms so cant just shorten easy .
next is i can do a 14ff front or i have a few trucks local getting parted out that have the dana 80 rear still in them and matching ratio so that would help . then i sould just slide in a set of cut off 60 tubes & inner "C" ends and weld up and have shafts cut and install .
let me know what you think and info that can help me . . . i might say screw it and just go newer rear 8 lug and std 60 front and mod the spring pad width and SRW it out over DRW setup .
