2wd rear axle brake line ?
K5DRAGER
Momence, IL
Messed up my rear brake lines during a swap, and have been looking for a place that makes new ones. Found some places but most want to sell a whole kit for around 200.00 All I need is the two that go from the wheel cylinders to the middle of the axle. Saw that LMC sells just those lines but they say that they are for 2wd blazers. Was wondering if anyone knows if they would work on my 12 bolt that I just put in. I'm currently using the old ones from the 10 bolt, but they're pretty messed up. Thanks
Is this for a current 2WD with a 12bolt swapped in? If so, the lines wiil be the same. http://www.classictube.com should have the lines in stock.
I have gotten all of my tubing from inlinetube.com. They sell the rear axle lines for $25.
Chris Lucas
<a target="_blank" href=http://www.captkaoscustoms.com>http://www.captkaoscustoms.com</a>
actually its a 90 4wd that I swapped in a 12 bolt was wondering if there was any differece. Thanks. By the way I'm going to call inline and see what they can do.
