2wd sector shaft clocked for 4wd steering?
MNorby
3/4 ton status
Powell, Wy
Wan pondering and figuring steering correction on my 71. Basically put a 4-5" lift on it and need to correct steering angles. Prog just go with a raised steering arm if I can find cheap but was thinking, If I put a 2wd sector shaft in the box can I run that Ford superlift pitman arm like we use on our crossover steering setups but clock it for front/back steering? The secter is splined all the way around with 4 misplined sectoins around it. Anyone try that? If it worked I would go that route then when I could scrounge a crossover steering arm I could re-index and be done. Make sense?
sweet, I thin I will just order one of those pitman arms and put one of my extra 2wd sectors in my box and be done then weh time for crossover jsut a steerng arm and draglink
