jonathon
I know you all use the 2wd drive steering boxes for cross over.. but what about as a replacement for our 4x4's with the regular push pull steering? Can the 2wd pitman arm be index properly?
a 2wd steering box is like $50 tops and crossovers around $400-$500 that might be whyIf you are going to all that trouble, why not just go crossover
plus throwing in a new box is not any trouble. what are you talking about?
seeIf you are going to all that trouble, why not just go crossover.
What drop pitman arm are you using? How much lift?
ORD has their kit for $380 + s&h right now.. very tempting, but I think I'll give a year and do the suspension first. It's going to get 3" TC E-Z rides up front and the ORD 2.5" Shackle flip with DIY4X's 6" shackles. Got the the flip and shackles, that's half the expense right there.. Shocks, drop pitman arm, front springs, and rear u-bolts(got 10 bolt front u-bolts already) and I'll be set.
Yeah that makes a lot more sence then
