goathearder
Hey all,
I am in the midst of my crossover conversion and i bought an upgraded 2wd box from AGR to use for it. I bolted the box in today and now the flexible coupler on the steering shaft doesn't fit over the input of the new steering box.
Took a measurement and the input on the new box is like 3mm larger than the input on the old box. Did 2wd trucks use a different steering shaft? Is it possible the PO did something weird with the steering and I don't have an original box? Anyone have an box lying around that the could take a measurement of the input shaft for?
This is a 73 K5 btw.
Has anyone run into this before? If so, how did you fix it???
Thanks,
John
Thanks,
John
