BDAMNRZ
So I had the 2wd box apart last weekend. Replacing some seals. Put it back on, everything lined back up, wheel straight and all. Problem is turning to the left will not even bottom out the stop on the knuckle. Turning right will bottom out the stop and wants to keep going. Double checked the splines on the sector shaft. Pulled p arm and re-centered the shaft by going lock left with the wheel. All the way right counting rotations, dividing by to to center everything. Still no good. Besides, you only have adjustment every 25* anywayon the sector shaft anyway. I am going to pell the input shaft again tomorrow and see if it as anything I missed. Any comments?
I was going about it the wrong way as far as adjusting goes. Thanks for the info guys. Hving that steering box apart just threw me off, I thought for sure I had put that thing back together wrong.
