k20: The Burb is getting 52" springs on the front with 6-7" shackles. By guesstimation, thats 4" lift from a stock 4wd height. I also have access to the 4wd box, pitman arm and draglink from a stock 4wd with a 10b, but I'm handing this truck off to a friend and dont want to rob a ton of parts which is why I wanted to know how much 2wd stuff can be reused.
sweetk30: Can just the pass side be replaced, cuz my reading was that both sides had to be replaced, and thats pushing the budget when adding in the cost of the crossover setup.
All: How hard is it to change out the sector shaft? I'm mechanically capable, but dont have a full-out auto shop, so tools are limited. Also, what is a good size for a u-bolt on a D44 with 52" springs?
