3", 4", 6" yank straps, tree savers AND rope
four_by_ken
Allenton, MI
Brand new... American made.* These are not your cheap Chinese straps.
$40 for the 3"x30'.* *Blue.
$50 for the 4"x30'.* Blue. EDIT Now yellow
$100 for the 6"x30'.* *Yellow.
$200 for the 6"x50'.* *Yellow. Shipping will be updated for these once I have the first in my hands.
$28 for the tree saver with cordura sleeve.* Yellow and black.
I can combine shipping to save on multiple strap orders in some cases.* 3", 4" and tree savers can ship by USPS flat rate boxes of $10.70 each.* 6" straps are dependent upon zip code and weight.
The straps I have made are 7500lbs per inch wide.* So, that is 22,500lbs for the 3" and 45,000lbs for the 6", etc.
Tree savers have a breaking strength of 67,200lbs.
Just a note that there are a lot more to straps than just breaking strength.* *And like everything advertised... there is no regulation on this.* I would put my straps up against a twice as wide Chinese strap.
As you can see my straps have cordura added to the loops to make them last longer.
As a general rule of thumb, a strap should be purchased that is rated at roughly 3 times the weight of your vehicle.* If in question, go larger.
These are the kinetic straps... the yank kind... the kind that stretch.* The industry does not have a standard on naming.* One companies recovery straps are another companies tow straps, etc.* Just for positive clarification... this are intended for yanking a stuck vehicle out.
Glad I looked to see what you were vending. I need a strap and I can hopefully free up some cash next month.
Added the 2" ATV straps.
EDIT
I decided against the 2" straps. I just dont see them being requested enough.
Just put a 6" through a work out at a local bog. It was used with a deuce:saweet: and a half working as the recovery rig.
So how does one go about buying one of these things? I don't see a website or anything listed for you.
Are these going to be blue in color like you have posted here? I swear you had said that somewhere but you must have edited a post or something.
Sending e-mail now.
Sending e-mail now.
Yes, they are blue. I did edit my first post to try to clean it up a little bit.
The 6" straps I have right now are yellow. The next run of 6" should be blue.
(your e-mail has been answered)
Oops, should have told you which one i wanted but payment should be self explanatory. :doah:
i'll be getting one soon ..... 6x30 have the blue ones come in yet or are they still yellow ???? dont really care but i like that blue
Still yellow for now. I am trying to get the blue worked out... but the cost is just too high right now. I cant order as many of the 6" as I can the 3". Trying to work my way up on things like this.
Just let me know when you are ready!
