3/4-ton and/or 1-ton bolt up's?(year?)
84HOOLIGAN
Orcutt, CA
Is there a 3/4-ton or 1-ton 'year bracket' that will bolt up with minimal modifications? :dunno:
I'm sure 3/4-ton will bolt right up, but I'm not sure what else will have to come with it... don't want my baby outta commission for too long. You know!
Bolt up to what, a Blazer???
3/4 ton will, but 1 ton you have to move the perches and the shock mounts are opposite...
Stock (drive-tran-wise) 1984 K5 Blazer.... Guess I should have added that... TH400, NP208, 1/2-ton.
Rear 14 bolt:
1/2 ton and 3/4 ton are interchangeable except for ubolts (and plates) and most likely the driveline ujoint (napa 448 is a 1310/1350 conversion joint IIRC)
1 tons are the same except that the spring spacing is 2" too narrow, so you need to move perches.
Front:
All axles use the same spring spacing and 1310 ujoint. Ubolts and plates are the only difference.
