3/4 ton axle swap ?
Cole
Kentucky
will my 1/2 ton drive shafts work with the swap...do u just change u joints or do u have to get special adapters or new drive shafts?
the search feature is your friend.
but yes they will work
in the front a 3/4 ton axle is the same, driveshaft wise, and in the rear you need a conversion u joint that can be found at any auto parts store
they might. you'll need different u-joints at the axle end.
this is covered A LOT. you're new so you didn't know.
they will physically fir under the truck. you'll have to do a few things to make them work.
