Sold 3/4 ton axles ready for crossover
bigjimmy82
1-Ton Status
New Albany, IN
Willing to separate front and rear axles. Price is SOLD via Craigslist
Front axle:
1979 GM 10bolt front 3/4t suburban
3:73 gear ratio
Trout industries rock ring around cover
Newer (6-7,000miles) moog ball joints, wheel bearings, spindle on passenger side that was needed, rotors, etc.
Dana 44 flat top knuckle on passenger side, off road designs steering arm.
Includes ORD heavy duty draglink(not shown) and tie rod
Full set of spare axle shafts
Add a 2wd steering box and you have all that is needed for crossover steering conversion.
No issues with axle, only removed to swap Dana 60.
Rear Axle:
14 bolt full float
10.5" ring gear
3:73 gear ratio
Still has drums installed and parking brake cables
In good used condition, may need brakes
Overpriced?
Seems like a good deal to me. I need the drag link and the tie rod, and the deal is tempting.
I could run up to you if you decide to part it out. I don't have room for the FF to sit otherwise I'd make an offer on all just to get the steering stuff.
