3/4 ton axles
muddybuddy
1 ton status
Northern, VA
lookin for some 3/4tons to put under my diesel k10, 3.08s and 35s arent going to cut it. im looking for either 3.73 or 4.10 so can use the overdrive. need to be in good condition so i can do the swap in an afternoon, dont want to have to take them apart and rebuild them. let me know what you got.
ive got an open 14bff and an open D44 off a 78 gmc with about 75,000mi on them.. but im kinda far away.
My friend has a set of 3:73's in Pa he'll sell for $350 complete ,said he could possably meet half way for some gas $$$
I'll get some pics posted up ,mabey tomorrow
They are in good condition and are still under the truck
got a 44 8 lug with 488 welded..new ball joints..steering arm block..its my buddies i think he wants 400 to 500...its in powatan,va about 3 hours from jmu...
I know I could get you a set, but might need some work, mother nature and NYS salt do wonders to axles that sit.....
id rather have axles that i can just drop in. ive gone through rebuilding axles for my k5, and that was both time consuming as well as emptying the wallet.
i might not mind a LITTLE work, depends on what it is
Axle pics
Here's a few pics ,sorry about the quality just got them out about an hour ago & it was dark .
Also will have a 203 X-member from the same truck but, I'll have to ask him what he wants for it
Um...i thought the 6.2 was going in the blazer???:confused:
it was originally going to, but this truck is in much better condition that i had originally thought. plus now that ive got it, my parents want to keep it to use for various tasks since we dont have a pickup until now. its got a plow as well, so my rents want me to use it to make some money in the winter. a buddy is probably going to buy my 350/700r4/208, so thats how ill fund another 6.2 to put into the k5, since ive pretty much acquired all the other stuff i need to do my tranny/t-case swap.
thanks for the pics. are you sure thats a 10b and not a d44? would he take $300 for the set?
I have a set. Dana44 and 14ff out of a 1979. 4.10 gears. Front and rear had all new bearings, seals and warn hubs last september. I ran the k5 for about one year. I am going to guess 2500 miles. The rear has disk brakes on it and a heavy diff cover. 1/4 with 3/8 ring if I remember correctly and 1350 yoke with ubolts. I am asking $300 for the pair. They are located in central pa at 16823. If you want some pics send me your email and I will get them over to you. These are the ones that came out of the white k5. You could take these and put them in no problem top off the gear oil and run them.
Let me know whats up. Jim,
