3/4 ton caliper brackets for a 1972 D44.
Something like this where you slide the mounting points out and weld, then fill the gap.
Do you have any pictures of the two side by side? Have you verified that the rotor won't rub? I'm tempted to rework what I have, but there is risk without a template.
Rotor dia is bigger so backing plate is bigger .
Do you have any measurements of the 2 styles of backing plate? I may measure my 6-lug ones to see if the new rotor overhangs. It's OK if it does, not OK if the rotor hits the bracket.
sorry but i only play with dana 60 fronts anymore.
I will dig them up and check that.
Will be a couple of weeks though
