nbrown2500
3/4 ton
I have a 14 bolt SF in the rear of my blazer. I just got my TC springs and new U-bolts. I ordered the 3.5" I.D. U bolts for spring installs from TC. The new U-bolts don't line up with the holes in the top plate. The holes in the top plate are narrower then the new U-bolts. Did the PO use 1/2 ton plates with the 14 bolt SF and bend the old u-bolts to fit in the holes? Do I need to order the ORD spring plates for the 14 bolt SF axles? Any help would be great, Thanks.
