14bff is easy gear swap. Grab that matched set and get them under your truck.
Will be worlds better than 3.08 at 4.1
he already has 4.11s, just in a 44/12 combo
Oh confused with another axle thread sorryhe already has 4.11s, just in a 44/12 combo
I did the same thing - gett’n old I guess…Oh confused with another axle thread sorry
Pricing depends on a lot of things. They were in lots of trucks but if there is one already out and ready to go in good shape $500 may be reasonable. Especially if it's the gear ratio you want. I did pull mine for that price but with a grinder it didn't really take very long.@HankScorpio so $500 sounds a bit high? I'll see if I can get it for less.
@sweetk30 not sure what you're recommending; the link just takes me to the home page. What should I look for?
Thanks!
The standard Detroit locker for a 14bolt.@sweetk30 I found the page with the leaf spring swap kits. Thanks!
@HankScorpio which locker did you go with?
I did new brakes with new calipers on mine. The bearings were fine so just new seals on the hubs. New Ruffstuff diff cover, a lubelocker gasket and a Detroit for the diff. You can order the brakes from rockauto for half the price of the local parts stores if yours are worn out.I bought the rear for $500. First purchase towards the build so I'm pretty excited. Now just to save up the funds for the D60 and I'll be able to get to work.
