3/4 ton spindles on to 1/2 ton
1637
Registered Member
la calif
i have a 82 two wheeldrive with 12.50 x33x15 tires,is there a eazy way but 3/4 ton spindle on and keep my same 5 lug wheels,i think i can bore out my hubs for the 3/4 ton bearings but what do i do about the caliber????/
Are you trying to run 33's on the front? Swapping the spindles won't help with the clearance issues. Swapping in some 3/4 ton springs might make the front end sit higher. I'm not to familiar with the wheel bearings on 2wd's, so I don't know if they are the same between 1/2 and 3/4. I would not suggest boring out the hubs. Calipers are the same between 1/2, 3/4 and 2/4 wheel drive.
The only benefit I can think of would be an extra inch of brake rotor, but it's really not worth the trouble. I don't see the point.:dunno:
1637
iam just trying to get bigger wheel bearing,the outer 1/2 ton is realy small.
you need everything from a 3/4 ton 2wd truck, spindles, springs, control arms, etc. Everything is different.
Your hubs will handle the 33" tires fine.
