rgorsuch87
Ok I've got an 86 with a 4" lift and 35's. I've already busted a front axle shaft so I know more are in the future. My question is should I get 3/4 ton axles or beef up my 1/2 tons? If I go to 3/4 tons what should I be looking for? And how much work is involved with doing a 3/4 ton swap? Am I looking at redoing the steering, brake system, springs, shocks?
Just not sure what way to go, so any advice or ideas help. Thanks
. If you're sticking with 35's then get a new axleshaft and some alloys for the rear, and leave it alone. The front probably broke from a crappy u-joint anyway.
