3 inch lift with 33's
blazingboy
Georgia
3 inch lift with 33\'s
Do yall think a 3 inch body lift with some 33's would make my 87 K-5 Blazer look that much bigger than stock or should I go with a 4 inch with 35's
Re: 3 inch lift with 33\'s
You should go with 4in and 35's cuz I mean... it's going to be big but after a while you're gunna get used to it and want biger and biger. So start big i guess lol. You might have to do a lil triming if you do any flexing or sharp turns
6in 87' K5 w/ 35" BFG muds.
305/Sm465/ NP208
Kn, 4.56's.
In desperate need of a rebuild.
Next- Eaton mech locker... Flows.
i run a 3" body, looks way bigger than stock, i wanna run 35s
with my 3 inch body, might need to trim a little, maybe.
i got 33s now save 3 of my 5 are flat
You will need to trim, definitely.
My tires rubbed with a 4" suspension and 35s.
Tim
'84 Chevy K10, lifted, loud, fast, and 3/4 ton axles
I have a 4" suspension and BFG AT 35's. They rub under high flex and if I hit a bump when turning sharply. It definately needs to be trimmed! Other than that, the gears should not be disregarded when lifting and going to bigger tires or you might end up putting more $$$ in that was planned. Just someting to consider before beefing up the tires...
'84 K5 Blazer 4"Rancho R/B w/Quad Diamond Back front 350/TH700r4/NP208/35" BFG AT/10 bolt F&R
Washington, USA
