3-speed to 4-speed conversion
aksidentproan
Maryland
I got a line on one and was wondering what would be involved. Could I just move my current crossmember or do I have to find a new one? Is the 4 speed(SM465) so much longer that I would need new driveshafts? If I get it it comes with an NP205 and adapter. Thanks.
Evan
im doing the same thing. i did a thread yetsreday here and in the garage. no one said anything about moving the crossmember. if you add a lift the length will help. the biggest prob everyone seems to refer to is the pedal rod to the master placement.
nathan
I went from a 3 speed with a Dana 20 to a 465/205, and I had to use the crossmember from the truck that had the 465/205. That crossmember has about an inch more drop in it, and the 205 would hit the floor pan with the one that came in my Blazer with the 3 speed/D20.
Ok. I drove to BWI Airport yesterday and picked up my 465/205 combo that I got from batmanjr. I am still unclear on the crossmember situation. The 4-speed with the 205 is a few inches longer then my 3-speed with a 205 so do I have to relocate the crossmember or just modify the area where it mounts so its 1" lower? If I have to get a crossmember from a 4-speed truck where could I find one? First generation blazers a few and far between in Maryland. Thanks.
Evan
The crossmember is the same on all NP205 first gens. You can use one from a TH350/NP205 with your SM465/NP205. You also need the side mount for the TC to the frame.
You do not have to move the crossmember back. It mounts in the same frame holes. If you had a Dana 20 to start with, you will either need to find a 205 crossmember, or space your old one down about an inch. I am not sure of the exact amount of difference in drop. I did try to install the 205 with the Dana 20 crossmember though, and it did hit the floor pan, so I know you have to drop it some. The bracket that mounts the side of the t-case to the right frame rail also uses the same holes for the D20 or the 205.
Poster: aksidentproan
Subject: Re: 3-speed to 4-speed conversion
Can I use the mechanical clutch(not hydro) setup from my 3-speed on the SM465? Thanks.
Evan
Comeon people, Do you really think Chevy would have a different clutch linkage for the 3 spds from the 465??? /forums/images/graemlins/confused.gif /forums/images/graemlins/deal.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif
