This may not be a direct comparison but it’s the easiest one in my head to compare at the moment.Who did you check with? There's a video of a guy swapping the gears side to side, but what does making the gear push in the opposite direction make any difference? The stories of "bias ratio" make you think the gears are cut at a different angle between a front and a rear.
