I have an 86k5 (305) that I transplanted a 350 into this past month. Any how I have been sorting out this q-jet and I am getting closer and more efficenct with this carb. I was wondering if anyone has the baseline jet numbers that came in the 305 and base line jets that came in the 350.
Currently I am running the carb off my 305 on the 350 however i have added the G hanger and the DR rods wich did help but I am still getting the q-jet bog when going into passing gear. I have been through all the tuning from the q-jet books, tuneing threads etc. When I tighten the spring preload on the sec. air valve it gets better but the truck is more slugs, so I know that I am creating a lean condition when the air valve opens. I am thinking that the 350 carb has bigger mains and I need to go that direction....
From a dead stop there is next to no bog as I am getting that extra pump shot that helps with that lean condition and your not pulling as much air at that point....
