305 TBI on a 350? how hard?
wheeler
New Jersey
My friend is giving me a 95 1/2 ton pickup with a 305, just wondering how hard it would be to make that fuel setup work on a 350 engine? do i need bigger injectors? different computer? ill be getting the whole truck so any sensors and harness and stuff like that wont be a problem. Im a complete noob when it comes to chevy fuel injection...so please be kind. Thanks
Forgot to add, its a 95 4x4 700r4 that im getting and my truck is an 84 k5, with a 92 350, was in truck when i got it, converted to carb, turbo 400.
You can swap the entire TBI system but you will need 350 injectors and also a chip for a 350 to run correctly.
I'm working with a 95 TBI computer. I think the 95 1/2 ton Vehicle Speed Sensor (VSS) could cause some headaches if the computer does not have the VSS information.:confused: The 95 computer needs the information from the VSS to operate the engine correctly. Older TBI computers were easy to bypass the need for a VSS. Is the 95 1/2 ton an automatic transmission pickup? I think some of the manual transmission 1/2 ton pickups in the early 90's still used the older computer, but I think by 95 all the 1/2 ton pickups used the new computer.:confused: Maybe when you get the pickup, you can post the computer part number ... then the computer can be identified as new / old.
dave w
Thanks guys, should be a good start for me. Dude said it was a 95 with a 700r4... I don't doubt he is wrong on one of the two though lol. I'll have to look further when its in my driveway.
You will also need to swap in a 350 knock sensor and a 350 ESC module. The module is the black box located on the passenger side of the TB.
The KS and ESC module from the 305 wont work well on a 350.
