84ever
Registered Member
My '84 K5
305 with only 92K miles on it was running great except for the worn out cam and rings
. Yes, only 92K, I bought it in '87 with 50K and the original tires. Seemed to go south fast the last couple of months until finally I wasn't sure if it would move anymore. Had it replaced it with a 350 crate engine. It's running pretty good but needs some tuning. It knocks a bit under moderate acceleration. Also noticed when I start it when it's hot it cranks a bit hard like it's got some ungodly compression and I hear it diesel for a split second until it starts. Not sure what's up with that
. There's a small valve tap so we're going to readjust the valves and see if that helps.
I'm not quite sure what the timing should be for the 350, the decal for the 305 called for 4deg BTDC so that's what I set it at. The distributor is for the 305 and I haven't bypassed the ESC yet although the knock sensor isn’t working. Since the 350 didn't get the ESC I'm thinking I will end up bypassing it. I checked out the timing over the RPM range and found that the dist vac advance kicks in between 2250-2500 RPM (no load) and adds about 18deg max. At 3500 RPM no load I've got about 38 deg BTDC. Seems like a lot. I could be off by 1 or 2 deg with the measuring but not much more than that. Not sure if this timing is reasonable or not. I put a vacuum gauge on the dist vac line on the dash and noticed it knocks even with vacuum too low for the advance to kick in. The dist is brand new (yeah, the installer put in a new 305 dist with the 350, go figure
) and there is no adjustment short of messing with springs and weights. The manufacturer says the advance is the same as the 350 dist, the only difference is the connection for the ESC.
I've got the dist connected to ported vac, I think. The original M4ME carb has three small ports labeled J, B, and H on the decal. Only the B is labeled on the carb. The B appears to be manifold vacuum when I measure it. The other two seem to measure ported vacuum, about the same. The decal shows the dist vac on the B port for the 305 but when I tried this with the 350 it barely idles, with way to much in the timing. Not too surprising though. Not sure why the 305 ran OK with manifold vac on the advance.
Anyone know the difference between the J and H ports on the carb?
Anyone know what the original hose routing was on the decal for the 350 Federal? I think I read that the 350 was only available on California K5s for 84. Don't know if that's true or if it means that all the 84 K5 350s had computer control (and none of this vacuum control stuff) or not. The on-line parts catalogs still show two thermal vacuum switches for the 350, just like the 305, except one switch is a different part number. So I’m thinking the 350 vacuum plumbing was probably similar to the 305 but I’d like to know for sure. Don’t know if any of this plumbing could be contributing to the knock or not.
. There's a small valve tap so we're going to readjust the valves and see if that helps.I'm not quite sure what the timing should be for the 350, the decal for the 305 called for 4deg BTDC so that's what I set it at. The distributor is for the 305 and I haven't bypassed the ESC yet although the knock sensor isn’t working. Since the 350 didn't get the ESC I'm thinking I will end up bypassing it. I checked out the timing over the RPM range and found that the dist vac advance kicks in between 2250-2500 RPM (no load) and adds about 18deg max. At 3500 RPM no load I've got about 38 deg BTDC. Seems like a lot. I could be off by 1 or 2 deg with the measuring but not much more than that. Not sure if this timing is reasonable or not. I put a vacuum gauge on the dist vac line on the dash and noticed it knocks even with vacuum too low for the advance to kick in. The dist is brand new (yeah, the installer put in a new 305 dist with the 350, go figure
) and there is no adjustment short of messing with springs and weights. The manufacturer says the advance is the same as the 350 dist, the only difference is the connection for the ESC. I've got the dist connected to ported vac, I think. The original M4ME carb has three small ports labeled J, B, and H on the decal. Only the B is labeled on the carb. The B appears to be manifold vacuum when I measure it. The other two seem to measure ported vacuum, about the same. The decal shows the dist vac on the B port for the 305 but when I tried this with the 350 it barely idles, with way to much in the timing. Not too surprising though. Not sure why the 305 ran OK with manifold vac on the advance.
Ya think that might cause just a little bit of knock?
